show mrp ports
show mrp ports {port_list}
Description
Shows the MRP timers configured on the given list of ports on the switch.
Syntax Description
mrp Multiple Registration Protocol.
port_list Ports on which MRP timers are configured or unconfigured.
Default
N/A.
Usage Guidelines
Use this command to view MRP timers configured on the given list of ports on the switch.
# show mrp ports 1, 4, 5
Ports      Join Time (ms)            Leave Time (ms)            Leave All Time (ms)            Periodoc (ms)            Extended
        Refresh (ms)
    1                 200                       600                           10000                     1000                 10000
    4                 300                       800                           10000                     1000                 10000
    5                 200                       600                           10000                     1000                 10000
This command was first available in ExtremeXOS 15.3.
Output for periodic and extended refresh timers added in 15.3.2.
Platform Availability
